boe
Jun 09, 2023Luminary
M4300- multiple VLANs connected to GS510PP
Hello, I'd to connect port 48 of an m4300 to port 1 of a GS510tpp. I have 5 vlans. VLAN 10 is my default vlan for all wiring e.g. servers, switches etc. I can't seem to figure out how to ...
boe
May 24, 2025Luminary
Thanks - I contacted netgear and they spent a lot of time scratching their head too. For some reason the switch was no longer getting DHCP. Everything else on the network gets dhcp no problem but the switch had some glitch even though it had been working over a year. I put a static IP on it and it worked fine.
schumaku
May 24, 2025Guru - Experienced User
Wild idea: Have configured by accident the Management VLAN on the MS510T[xxx}? This would require of course a tagged connection for the VLAN serving DHCP to that switch.
