belhassench
Sep 08, 2019Aspirant
M4300 12x12 Problem speed with qnap 20Gb Lacp configured
Hello I have problem with Netgear M4300 12x12 with Qnap TS-EC2480U R2 configured on each other 2 x 10Gb Lacp . The link is up , but problem in speed. when i copied from freenas (10gb + 1...
DaneA
Sep 09, 2019NETGEAR Employee Retired
Welcome to the community! :)
Kindly answer the questions below:
a. What is the brand/model of the fiber modules you are using between the M4300-12X12F and the QNAP TS-EC2480U R2 as well as between the M4300-12X12F and FreeNAS?
b. What is the bonding mode (or Hash mode) configured on the QNAP TS-EC2480U R2 and FreeNAS?
c. Is LACP configured also between the M4300-12X12F and the PC?
d. What is the behavior of the 10GBASE-X SFP+ port LEDs on the M4300-12X12F switches?
e. What is the current firmware version of the M4300-12X12F?
DaneA
NETGEAR Community Team
belhassench
Sep 11, 2019Aspirant
Thank you for the reply
The firmware of the switch is 12.0.7.10.
The model of all fiber optic connected to M4300 :
- Lag1 between S3300 (First Floor) and M4300 : AXC761(Netgear) LACP.
- Lag2 between S3300 (Ground Floor) and M4300 : AXC7610(Netgear) LACP.
- Lag3 between S3300 (Second Floor) and M4300 : AXC7615(Netgear) LACP.
- Lag4 between M4300 ---> Qnap TS-EC2480U R2 : 02 cable : SFP-H10GB-ACU7M , CABLE-STRG Kawasaki 594060003.
- Lag5 between M4300 ---> Freenas server APY : 02 cable : PSF1PXA3MBLLN (Same Model).
The protocol used between Qnap and M4300 is lacp configured in Qnap 802.3ad dynamic.
And same in freenas. (STP off , Static off).
The led port in M4300 Swetch is green and 10G Full (The swetch is L3 switch).
LACP is not configured between the M4300-12X12F and the PC (L3 switch only).
- DaneASep 19, 2019NETGEAR Employee Retired
I apologize for the late response. :(
Let us update the firmware of the M4300-12X12F switch to the latest version which is v12.0.7.17 and you can download it here. Then, check if the same problem will occur.
Is your PC connected with 10G ethernet connection to the M4300-12X12F switch?
DaneA
