fxn123
Feb 22, 2021Initiate
M4300 OpenFlow Configuration
Hello Everyone,
I am using the M4300 switch -- to implement the openflow protocol. The SDN Controller I am using is ONOS. I am having a simple linear topology which is I have connect SDN controller (10.18.206.12) to network and the Netgear M4300 switch (Managment ip is 10.18.206.18) is connected to SDN using OOB, I have configured two host with static-ip (10.18.206.14 and 10.18.206.16 respectively). All with subnet as 255.255.255.0
When I enable the openflow the ping between two is not reachable. But the switch can reach the SDN controller and vice-versa. But the host 1 and host 2 are not reachable. Though both the host are visible on the SDN controller topology as hosts.
Also, I am able to add flows in switch.
I have tried all the CLI commands mentioned in the manual. Still I am not getting desired output. I would like if anyone can give any input and help me to solve this problem of mine.
Please, let me know what can be done. Thank you!
Highly appreciated.
Hello DaneA,
Yeah, I got a solution, it was more on the controller side.
- DaneANETGEAR Employee Retired
Welcome to the community! :)
Found out that you have already opened a support ticket with NETGEAR Support. You may want to share the progress of your support ticket here.
DaneA
NETGEAR Community Team
