Laoch
Dec 05, 2018Tutor
OpenFlow documentation
I am looking for OpenFlow documentation for the M4300 series switches. I do see the commands described in the CLI reference but I do not see any mention in the User manual or the Software Administration Manual.
The Netgear M4300 documentation is excellent except when it comes to OpenFlow, it is like they want to keep it hidden for some unknown reason. Like anything, it is not difficult once you understand how. I put a primer on how to configure OpenFlow on my website:
http://www.obriain.com/primers/netgear_M4300_OpenFlow_Config.php
- DaneANETGEAR Employee Retired
Hi Laoch,
Welcome to the community! :)
I inquired your concern to the higher tier of NETGEAR Support. As per the higher tier of NETGEAR Support, the OpenFlow configuration is only available via CLI.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
- LaochTutor
