Laoch
Feb 04, 2019Tutor
Management IP goes offline with OpenFlow is enabled
The management IP on the M4300 goes offline when OpenFlow is enabled.
(SW) #ping 198.8.8.205
Pinging 198.8.8.205 with 0 bytes of data
Reply From 198.8.8.205: icmp_seq = 0. time= 1 msec.seq = 1. time <1 msec.
Reply From 198.8.8.205: icmp_seq = 2. time <1 msec.
----198.8.8.205 PING statistics----
3 packets transmitted, 3 packets received, 0% packet loss
round-trip (msec) min/avg/max = <1/<1/1
(SW) #configure
(SW) (Config)#openflow enable
(SW) (Config)#1970-01-01T01:10:10Z|00076|rconn|INFO|fastpath<->tcp:198.8.8.205:6633: connecting...
1970-01-01T01:10:10Z|00077|rconn|INFO|fastpath<->tcp:198.8.8.205:6633: connected
(SW) (Config)#exit
1970-01-01T01:10:20Z|00078|rconn|ERR|fastpath<->tcp:198.8.8.205:6633: no response to inactivity probe after 5 seconds, disconnecting
1970-01-01T01:10:20Z|00079|connmgr|INFO|fastpath<->tcp:198.8.8.205:6633: 1 flow_mods 9 s ago (1 adds)
1970-01-01T01:10:21Z|00080|rconn|INFO|fastpath<->tcp:198.8.8.205:6633: connecting...
1970-01-01T01:10:22Z|00081|rconn|INFO|fastpath<->tcp:198.8.8.205:6633: connection timed out
1970-01-01T01:10:22Z|00082|rconn|INFO|fastpath<->tcp:198.8.8.205:6633: waiting 2 seconds before reconnect
1970-01-01T01:10:24Z|00083|rconn|INFO|fastpath<->tcp:198.8.8.205:6633: connecting...
1970-01-01T01:10:26Z|00084|rconn|INFO|fastpath<->tcp:198.8.8.205:6633: connection timed out
1970-01-01T01:10:26Z|00085|rconn|INFO|fastpath<->tcp:198.8.8.205:6633: waiting 4 seconds before reconnect
3 packets transmitted, 0 packets received, 100% packet loss
round-trip (msec) min/avg/max = <1/<1/<1
I understand why now. The SDN Controller take control of the ports once connected and the connection drops. Best to access the SDN Controller via the OOB port. The Netgear M4300 documentation is excellent in general except when it comes to OpenFlow, it is like they want to keep it hidden for some unknown reason. Like anything, it is not difficult once you understand how. I put a primer on how to configure OpenFlow on my website:
http://www.obriain.com/primers/netgear_M4300_OpenFlow_Config.php
1 Reply
- LaochTutor
