koralle
Feb 15, 2020Tutor
M4300 24X: sudden restarts
Hi, i have since months sudden restarts with a M4300-24X (Firmware 12.0.9.3) in a single router setup. I use mostly LAGs with 2 ports for every system (Layer3+4 mode) and has disabled the most defa...
wuebra
Mar 14, 2020Aspirant
kevin_hong wrote:Hi wuebra ,
Could you please privode the tech support file to me? i will try re-created the issue and it will be helpful to find out the issue root cause .
How-do-I-send-diagnostic-files-from-my-Managed-Switch-to-NETGEAR-community-moderators
Thank you
What kind of crap does support take off?
The support simply closed my case!
The switch restarted tonight. Syslog logs are available
wuebra
Mar 18, 2020Aspirant
suddenly nobody says anything!
The support blames each other.
The fact is: I have 3 switches, 2 of them are broken (6000 €) and I don't have a CPLD patch either
- LaurentMaMar 18, 2020NETGEAR Expert
Hi wuebra and the Community
Please be sure that the NETGEAR Tech Support team, the NETGEAR Engineering team and the PLM team are working on these issues. To date, most cases logged in our system are resolved after PSU replacement. We are in the process of getting all faulty PSUs back to Engineering for complete analysis (root causing) so that actions can be taken at the factory as we suspect faulty PSUs. Please understand that there is no correlation between the fan speed, the internal components heat and the reboot in all your posts above. The fans are on duty "dynamically", based on internal heat sensors. The CPLD function is to make sure the heat remains under the system MAX thresholds. The CPLD is increasing fan speed when the temperature of the internal components is getting closer to the MAX threshold. In all your explained situations above, this is not what triggers a reboot. By design, the system is shutting down when and only when the internal sensors are reporting internal heat at or above the MAX threshold.
wuebra is your case number finishing with 181? For that case we replaced two switches under RMA and the NETGEAR Tech Support agents don't get responses anymore since then.
In any case please send me your Tech Support case nuber so that I can help prioritize your issue. As we can't replicate the issue with our own devices in our labs, we are depending on close collaboration on site for exporting the logs etc. You can send me your case number or any help request using private message here.
We are very sorry for this reboot issue on that model, litterally thousands units of that model are working well in the field and I know how the frustration can be when one unit is rebooting intermittently. We shall resolve this issue, I can guarantee! Again, please send me your Case Numbers.
- koralleMar 18, 2020Tutor
Dear LaurentMa ,
we (Community) don't know the root cause, but the faulty PSUs are keeping the units on a higher temperature level. We don't know if this higher temperature are responsible for a reboot, but from the techsupport files it is the only sign, which is significantly different with a "good" and a "faulty" PSU. So your statement "no correlation between the fan speed, the internal components heat and the reboot in all your posts above is ignoring the visible signs, but maybe you know more about the root cause.
Best Regards,
Ralf
- wuebraMar 18, 2020Aspirant
Hi LaurentMa
I don't care what the problem is there. But I want this to be fixed! An important production of over 1000 employees is attached to it!
And it cannot be that 2 units are 70 degrees and the 3rd unit is only 45, even though they are stacked in a rack.
The worst thing is the support.
Here is my process
1st opening case 42391590
2. Support says CLPD Patch has to be imported
3. Call support to apply the patch
4. Support refuses to apply the patch and closes the ticket without a solution !!!!!!!!!!!
5. Opening case 42429694 & 42429695
6. Support would like to invoice and exchange the devices
7. Support suddenly wants to import a patch again
8. Support does not want to replace the devicesSorry, don't take it personally, but what the heck is that?
I have already sent all tech files and syslog files 3 times. Nobody cares!
