AlmostATech's avatar
AlmostATech
M4300-24x
VLANs not going across fiber connection
When I tag them, it becomes untagged even though others are tagged.
Also tried a Trunk and that did not work
  • schumaku's avatar
    schumaku
    Afraid, the crystal ball is not available here.
    Provide much more information what you had tried to configure, being from screenshots or from CLI example.
    Start with the firmware version, the SFP module versions, the fiber technology, wavelength, ...
    • AlmostATech's avatar
      AlmostATech
      I have a single-mode fiber between two buildings connected over the SFP ports. M4300-24x24 port 22 and M4300-52G port 51
      I have setup VLANs, 220, 230, 240, 260, 270  on both switches. I tag port 51 with the VLANs no issue, when I tag port 22 with the VLANs it switches it to untagged.
      In short, just trying to pass tagged traffic across the fiber.
      • schumaku's avatar
        schumaku
        Tell us a little bit more about the set-up. Firmware in place, SFP modules involved, ...
        The device Web UI does change the config from trunk to an access port probably? A Stack config in place? Using the IT UI or the AV UI, or missed to apply/save the config changes? Reads to me like there is anther management entity in this set-up, like an active Netgear Engage Controller software for example.
ProSupport for Business
