hpc-encs
Apr 12, 2024Aspirant
M4300-24x24F LAG-LACP configuration issues
Hi I have 2 x M4300-24x24F stacked, and some servers connected directly to them via 10G Copper cables, 4 cables per server (2 cables per switch/unit). My goal is to increase the bandwitdh usi...
- Apr 19, 2024
Simply put: You need at least the same amount of sessions like you operate physical links. Each session will be run on a dedicated addresses. A common misunderstanding, no matter if people talk about IEEE standard LACP load balancing, or eg. Cisco proprietary implementations.
hpc-encs
Apr 19, 2024Aspirant
Hi
It'd be much appreciated if you develop more your answer.
Thanks
schumaku
Apr 19, 2024Guru - Experienced User
