joshduguid999
Aug 28, 2019Aspirant
m4300-28G-PoE+ High CPU Utilization
Hello there. Using a m4300-28G-PoE+ switch for Dante audio, as well as multicast Video over IP. I'm seeing VERY high cpu usage, (averaging around 84%), and 50% or more of that is coming from ...
joshduguid999
Sep 13, 2019Aspirant
Glad to hear I'm not the only one with issues. A switch sitting at 80%+ CPU seems really suspicious to me. Mine doesn't creep up however, it jumps right to 80%+ after reset.
What is odd is I have another site with M4300 switches (stack of three, one M4300-96X and two M4300-28G) with WAY more going on, and only 40% CPU utilization.
Let me know how things work out with support.
Anonymous
Sep 15, 2019
Ok, for further analysis,Could you please provide the tech-support file of the Switch:
How do I send tech-support files from my Managed Switch to NETGEAR community moderators?
EricZ
NETGEAR employee
- VistaICTSep 15, 2019Star
Get in touch with support as Retired_Member mentioned. They are super helpful
- joshduguid999Sep 16, 2019Aspirant
Hey Retired_Member,
Here's the tech support file for you. Thanks for reaching out.
Josh D.
*************** show version ***************
Unrecognized command : show versionError! Command 'show version' doesn't exist.
Hence aborting TechSupport execution.*************** show running-config ***************
!Current Configuration:
!System Description "M4300-28G-PoE+ ProSAFE 24-port 1G PoE+ and 2-port 10GBASE-T and 2-port 10G SFP+, 12.0.6.6, B1.0.0.11"
!System Software Version "12.0.6.6"
!System Up Time "6 days 11 hrs 28 mins 34 secs"
!Additional Packages QOS,Multicast,IPv6,IPv6 Management,Stacking,Routing
!Current SNTP Synchronized Time: SNTP Client Mode Is Disabled
serviceport protocol none
serviceport ip 192.168.0.1 255.255.255.0 192.168.0.1
vlan database
set igmp groupmembership-interval 1 125
set igmp querier 1 address 192.168.41.1
vlan routing 1 1
exit
configure
no sntp client mode
stack
member 1 2
exit
no ip domain lookup
logging buffered 0
no ip routing
line console
exit
line telnet
exit
line ssh
exit
no spanning-tree
set igmp querier address 192.168.41.1
set igmp querier query-interval 60
classofservice trust ip-dscp
classofservice ip-dscp-mapping 34 5
classofservice ip-dscp-mapping 46 6
interface 1/0/1
description 'Remote Access PC'
exit
interface 1/0/2
description 'Screen Control'
exit
interface 1/0/3
description 'LivestreamRX Vid'
mtu 9000
exit
interface 1/0/4
description 'Proj Control'
exit
interface 1/0/5
description 'BackstageRX Dante'
exit
interface 1/0/6
description 'GreenroomRX Dante'
exit
interface 1/0/7
description 'LivestreamRX Dante'
exit
interface 1/0/8
description 'PodiumTX Vid'
mtu 9000
exit
interface 1/0/9
description 'Bottom Proj Control'
exit
interface 1/0/10
description 'SPARE 1'
exit
interface 1/0/11
description 'Top Proj Control'
exit
interface 1/0/12
description 'BackstageRX Vid'
mtu 9000
exit
interface 1/0/13
description 'GreenroomRX Vid'
mtu 9000
exit
interface 1/0/14
description 'CameraTX Vid'
mtu 9000
exit
interface 1/0/15
description 'ProjRX Vid'
mtu 9000
exit
interface 1/0/16
description 'Booth TSC-80'
exit
interface 1/0/17
description 'Theatre Core110f'
exit
interface 1/0/18
description 'SPARE 2'
mtu 9000
exit
interface 1/0/19
description 'Theatre Amp'
exit
interface 1/0/20
description 'BoothTX Vid'
mtu 9000
exit
interface 1/0/21
description 'SPARE 3'
exit
interface 1/0/22
description 'ProjRX Dante'
exit
interface vlan 1
routing
ip address 192.168.41.1 255.255.255.0
exit
ip management vlan 1 192.168.41.1 255.255.255.0
router rip
exit
router ospf
exit
ipv6 router ospf
exit
service dhcp
ip dhcp excluded-address 192.168.41.1 192.168.41.100
ip dhcp pool "AV"
lease infinite
network 192.168.41.0 255.255.255.0
netbios-node-type b-node
exit
no bonjour run
exit*************** debug crash & kernel logs ***************
*************** Debug crashlog 0 unit 1 ********
Displaying FASTPATH Crash Dump 0
For kernel Crash Dump - osapiDebugCrashDumpDisplay(x,1)
Crash Dump 0 is not found*************** Debug crashlog 1 unit 1 ********
Displaying FASTPATH Crash Dump 1
Crash Dump 1 is not found*************** Debug crashlog 2 unit 1 ********
Displaying FASTPATH Crash Dump 2
Crash Dump 2 is not found*************** Debug crashlog 3 unit 1 ********
Displaying FASTPATH Crash Dump 3
Crash Dump 3 is not found*************** Debug crashlog 4 unit 1 ********
Displaying FASTPATH Crash Dump 4
Crash Dump 4 is not found*************** Debug crashlog kernel 0 unit 1 ********
*************** Debug crashlog kernel 1 unit 1 ********
*************** Debug crashlog kernel 2 unit 1 ********
*************** Debug crashlog kernel 3 unit 1 ********
*************** Debug crashlog kernel 4 unit 1 ********
*************** Display stack-path information. ***************
Switch 2 does not exist!
Switch 3 does not exist!
Switch 4 does not exist!
Switch 5 does not exist!
Switch 6 does not exist!
Switch 7 does not exist!
Switch 8 does not exist!
