jdf12's avatar
jdf12
Initiate
Feb 18, 2018
M4300-28G-PoE+ & Tivo
Greetings -
We just upgraded from a M4100 to the M4300 (GSM4328PB), flashed the latest firmware on the 4300 to 12.0.2.20.
We have a Tivo Bolt and a number of Tivo Mini Vox 4K's at our facility, all connected to the same network switch.   The Mini's all connect to the Bolt for their tuners and to access the Bolt's disk via ethernet.   It all worked fine before the upgrade, but now the Mini's cannot see the Bolt (tried swapping in the old switch, and it still works fine.)
I have read that Tivo wants to broadcast on all ports, and is "chatty" which isn't a problem, but I cannot seem to figure out the combination of settings on the 4300 that allows the Tivo's to talk to one another.   Odd that this fails on the 4300 but not the 4100?    I have IGMP snopping turned off on the 4300, still doesn't work.
Thanks for any advice or suggestions.
Jon
  • jdf12's avatar
    jdf12
    Feb 22, 2018
    Thanks to Laurent's help we solved the problem.   Great support and incredibly responsive.
    For future reference and for anyone coming across this thread - for Tivo to work across an M4300 you need to disable IGMP snooping and MLD snooping.   Tivo, like a lot of consumer IOT devices, assumes a flat, "stupid" network for discovery.
  • LaurentMa's avatar
    LaurentMa
    NETGEAR Expert
    Hi Jon
    Thank you for your message and congratulations, M4300 series is NETGEAR top of the line and a great upgrade from M4100 series.
    Yes, all M4300 switches come with Layer 2 Multicast pre-configured (IGMP Snooping, Querier and Fast Leave enabled across entire VLAN 1) for convenient Video-over-IP deployments. As a founding member of the SDVoE Alliance, NETGEAR provides the backbone network that makes it all possible.
    If your Tivo installation was working fine on a previous M4100 switch, we need to check two things:
    1. Is the IGMP configuration the problem?
    2. Was there any other required configuration on the M4100?
    The Community can help you figure out. We should start with 1/ and "un-do" the L2 Multicast configuration in this order:
    • Using the Web GUI for instance, Switching \ IGMP Snooping \ Querier VLAN Configuration: delete the line "VLAN ID 1 - Querier Mode Enable - Querier VLAN Address 0.0.0.0"
    • Switching \ IGMP Snooping \ Querier Configuration: set "Disable" for "Querier Admin Mode"
    • Switching \ IGMP Snooping \ IGMP VLAN Configuration: delete the line "VLAN ID 1 - Admin Mode Enable - Fast Leave Admin Mode Enable"
    • Switching \ IGMP Snooping \ Configuration: set "Disable" for "Admin Mode" and for "Validate IGMP IP header"
    • Maintenance \ Save Config: check the box "Saving all applied changes" and click APPLY on the bottom right
    Please let us know how it goes after this, as a first step. Thank you!
    • jdf123's avatar
      jdf123
      First, thanks for the help!
      On my M4300, I did everything you suggested, a few small differences:
      IGMP VLAN Configurator: cannot delete the VLAN so set all options to Disable.
      IGMP Snooping Configuration:  all 3 options (Admin/Validate/Proxy) to Disable.
      Unfortunately, still doesn't work.    And again to test, I plugged everything together with a small, dumb switch, works fine.   I also looked at the M4100 options, nothing jumped out as being different.
      Thanks again - Jon
        LaurentMa
        NETGEAR Expert
        Hi Jon, thank you and sorry about the inconvenience. We need to root cause this behavior.
        I am suspecting the problem comes from default unregistered Multicast filtering (the switch filters / discards any unregistered Multicast flooding by default).
        I see several options / workaround here, but let me check internally before asking you anything. We'll be back in this thread asap.
ProSupport for Business
