N83
Oct 21, 2020Follower
M4300-52G can't get kernel image
I have a M4300-52g and when I boot I get this. It never gets to the "checking for application" so I can't seem to reset it or load any new firmare. Only the OOB port seems to be working, ...
DaneA
Nov 03, 2020NETGEAR Employee Retired
N83,
Welcome to the community! :)
Kindly access the article below and follow the initial steps but select option 9, to try to activate a backup image. If ever this works then the firmware image is corrupted on the now non-active partition.
M4300 - Resetting to factory default using the boot menu
Let us know how it goes.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
