mariu22sz
Nov 22, 2021Aspirant
M4300-8X8F conecting two devices form one subnet to two difrent ports
Hello i have m4300-8X8F configured like on picture with configured defult gw to 10.10.10.1. serv 1 is working fine and trafic is forwarded from and to subnet(public ip provaided by my ISP), now i t...
- JohnC_VJan 14, 2022NETGEAR Employee Retired
Hi mariu22sz,
My apologies. As per my understanding, you want to configure the serv2 the same as your serv1, is that correct? Have you tried to replicate the same configuration from serv1 to serv2 but using a different LAN IP? If serv1 is working just fine, then you can just copy the config and do it also on serv2.
John
NETGEAR Community Team
- mariu22szJan 18, 2022Aspirant
hi JohnC_V
I already have configured serv2. I'm trying to configure port 1/0/15 on the switch and i dont know how to do it.
"With my internet connection, I received a subclass of public IP addresses from my ISP
I configured on my switch static route to my ISP network and added IP address from that subclass to interface where it's connected → (1/0/9) I configured interface →(1/0/16) where is my serv1 connected by adding IP address from my subclass of IP addresses. Serv1 have access to the internet and is accessible from internet, everything is working grate for serv1. Now I want to connect serv2 to the port → 1/0/15 and i don't know how to configure port on the switch (serv1 and serv2 have IP addresses from the same subclass)"
