mikey59's avatar
mikey59
Guide
Aug 21, 2023
Apple devices cannot conect!
Stating yesterday, I have been having problems with iPhone, iPad, Macbook, connecting to Wi-Fi
It shows as available, but when connecting, it goes from connected to not 2 or 3 time & then just shows in my list of networks.
I have reset network settings & restarted phone numerous times, forgotten & rejoined numerous time,
Looking for suggestions!
  • Hi Ahiro
    Welcome to the community!
    You cannot manage a Smart Managed Switch using SSH nor command line. Instead, a Smart Managed Switch is managed used Web interface (GUI) through HTTP.
    Command line (CLI) and Telnet/SSH are one of the differences between Smart Managed switches and Fully Managed switches.
    If you require SSH over Putty, you should take a look to our excellent M4100 switch series, cost effective L2+ Fully Managed standalone switches here:
    http://www.netgear.com/managed
    • mikey59's avatar
      mikey59
      Guide
      Turned off private Wi-Fi address & now it keeps telling me the &$^%##*& password is wrong!!!
      This had been working fine since the beginning of the year - what would have suddenly changed to &%#$ that up?
      • FURRYe38's avatar
        Forget the connection on the apple device then re-connect with the WiFI Private IP address disabled.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
    Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
    I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
