NS_BL
Feb 27, 2017Aspirant
M4300-8X8F no connectivity with Juniper EX3300 (Juniper DAC)
Hello! I have few Juniper EX3300 switches connected using Juniper DACs and now purchased M4300 for test lab cluster. Can't get 10gbe link between EX3300 and M4300 to work - ports are always down...
atian
Hi, could you dump the eeprom on Juniper's DCC cable using the following command?
show fiber-port optics-info all
show fiber-port optics all
show fiber-port optics-eeprom all.
NS_BL
(M4300-8X8F) #show fiber-ports optics-info all
Link Link Nominal
Length Length Bit
50um 62.5um Rate
Port Vendor Name [m] [m] Serial Number Part Number [Mbps] Rev Compliance
1/0/1 Amphenol 0 0 APF13360028MY0 584990002 10300 A DAC
1/0/2 CISCO-TYCO 0 0 TED1552BVNJ 1-2053783-2 10300 P DAC
1/0/4 CISCO-TYCO 0 0 TED1546BA54 1-2053783-2 10300 P DAC
1/0/5 CISCO-TYCO 0 0 TED1546BA7K 1-2053783-2 10300 P DAC
1/0/6 CISCO-MOLEX 0 0 MOC154401QU 74752-9520 10300 08 DAC
1/0/7 CISCO-TYCO 0 0 TED1546BA1S 1-2053783-2 10300 P DAC
1/0/8 CISCO-TYCO 0 0 TED1552BVQC 1-2053783-2 10300 P DAC
(M4300-8X8F) #(M4300-8X8F) #show fiber-ports optics all
Output Input
Port Temp Voltage Current Power Power TX LOS Fault
[C] [Volt] [mA] [dBm] [dBm] Fault Status
1/0/1 N/A N/A N/A N/A N/A N/A N/A Remote Fault
1/0/2 N/A N/A N/A N/A N/A N/A N/A No Fault
1/0/4 N/A N/A N/A N/A N/A N/A N/A No Fault
1/0/5 N/A N/A N/A N/A N/A N/A N/A No Fault
1/0/6 N/A N/A N/A N/A N/A N/A N/A No Fault
1/0/7 N/A N/A N/A N/A N/A N/A N/A No Fault
1/0/8 N/A N/A N/A N/A N/A N/A N/A No Fault
(M4300-8X8F) #(M4300-8X8F) #show fiber-ports optics-eeprom all Port 1/0/1 vendor_name = Amphenol vendor_sn = APF13360028MY0 date_code = 130905 vendor_pn = 584990002 vendor_rev = A eeprom data = 03 04 21 00 00 00 00 00 04 00 00 00 67 00 00 00 ..!.........g... 00 00 03 00 41 6d 70 68 65 6e 6f 6c 20 20 20 20 ....Amphenol 20 20 20 20 00 41 50 48 35 38 34 39 39 30 30 30 .APH58499000 32 20 20 20 20 20 20 20 41 20 20 20 01 00 00 fa 2 A .... 00 00 00 00 41 50 46 31 33 33 36 30 30 32 38 4d ....APF13360028M 59 30 20 20 31 33 30 39 30 35 20 20 00 00 00 f6 Y0 130905 .... 37 34 30 2d 30 33 30 30 37 37 20 52 45 56 20 30 740-030077 REV 0 31 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 1 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................ ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................ ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................ ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................ ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................ ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................ ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................ ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................ Port 1/0/2 vendor_name = CISCO-TYCO vendor_sn = TED1552BVNJ date_code = 1512210 vendor_pn = 1-2053783-2 vendor_rev = P eeprom data = 03 04 21 00 00 00 00 00 04 00 00 00 67 00 00 00 ..!.........g... 00 00 03 00 43 49 53 43 4f 2d 54 59 43 4f 20 20 ....CISCO-TYCO 20 20 20 20 00 00 40 20 31 2d 32 30 35 33 37 38 ..@ 1-205378 33 2d 32 20 20 20 20 20 50 20 20 20 01 00 00 0d 3-2 P .... 00 00 00 00 54 45 44 31 35 35 32 42 56 4e 4a 20 ....TED1552BVNJ 20 20 20 20 31 35 31 32 32 31 30 30 00 00 00 06 15122100.... 81 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 74 04 3b 5b ............t.;[ 43 4f 50 51 41 41 36 4a 41 42 33 37 2d 30 39 36 COPQAA6JAB37-096 31 2d 30 33 56 30 33 20 01 00 46 00 00 00 00 cf 1-03V03 ..F..... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 53 46 50 2d 48 31 30 47 42 2d 43 55 33 4d 20 20 SFP-H10GB-CU3M 20 20 20 20 30 38 00 00 00 00 00 00 00 00 00 b5 08.......... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Port 1/0/4 vendor_name = CISCO-TYCO vendor_sn = TED1546BA54 date_code = 1511090 vendor_pn = 1-2053783-2 vendor_rev = P eeprom data = 03 04 21 00 00 00 00 00 04 00 00 00 67 00 00 00 ..!.........g... 00 00 03 00 43 49 53 43 4f 2d 54 59 43 4f 20 20 ....CISCO-TYCO 20 20 20 20 00 00 40 20 31 2d 32 30 35 33 37 38 ..@ 1-205378 33 2d 32 20 20 20 20 20 50 20 20 20 01 00 00 0d 3-2 P .... 00 00 00 00 54 45 44 31 35 34 36 42 41 35 34 20 ....TED1546BA54 20 20 20 20 31 35 31 31 30 39 30 30 00 00 00 ca 15110900.... 81 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 74 04 3b 5b ............t.;[ 43 4f 50 51 41 41 36 4a 41 42 33 37 2d 30 39 36 COPQAA6JAB37-096 31 2d 30 33 56 30 33 20 01 00 46 00 00 00 00 cf 1-03V03 ..F..... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 53 46 50 2d 48 31 30 47 42 2d 43 55 33 4d 20 20 SFP-H10GB-CU3M 20 20 20 20 30 38 00 00 00 00 00 00 00 00 00 b5 08.......... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Port 1/0/5 vendor_name = CISCO-TYCO vendor_sn = TED1546BA7K date_code = 1511090 vendor_pn = 1-2053783-2 vendor_rev = P eeprom data = 03 04 21 00 00 00 00 00 04 00 00 00 67 00 00 00 ..!.........g... 00 00 03 00 43 49 53 43 4f 2d 54 59 43 4f 20 20 ....CISCO-TYCO 20 20 20 20 00 00 40 20 31 2d 32 30 35 33 37 38 ..@ 1-205378 33 2d 32 20 20 20 20 20 50 20 20 20 01 00 00 0d 3-2 P .... 00 00 00 00 54 45 44 31 35 34 36 42 41 37 4b 20 ....TED1546BA7K 20 20 20 20 31 35 31 31 30 39 30 30 00 00 00 e3 15110900.... 81 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 74 04 3b 5b ............t.;[ 43 4f 50 51 41 41 36 4a 41 42 33 37 2d 30 39 36 COPQAA6JAB37-096 31 2d 30 33 56 30 33 20 01 00 46 00 00 00 00 cf 1-03V03 ..F..... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 53 46 50 2d 48 31 30 47 42 2d 43 55 33 4d 20 20 SFP-H10GB-CU3M 20 20 20 20 30 38 00 00 00 00 00 00 00 00 00 b5 08.......... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Port 1/0/6 vendor_name = CISCO-MOLEX vendor_sn = MOC154401QU date_code = 111031 vendor_pn = 74752-9520 vendor_rev = 08 eeprom data = 03 04 21 00 00 00 00 00 04 00 00 00 67 00 00 00 ..!.........g... 00 00 03 00 43 49 53 43 4f 2d 4d 4f 4c 45 58 20 ....CISCO-MOLEX 20 20 20 20 00 00 09 3a 37 34 37 35 32 2d 39 35 ...:74752-95 32 30 20 20 20 20 20 20 30 38 20 20 01 00 00 0b 20 08 .... 00 00 00 00 4d 4f 43 31 35 34 34 30 31 51 55 20 ....MOC154401QU 20 20 20 20 31 31 31 30 33 31 20 20 00 00 00 bb 111031 .... 81 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 74 04 3b 5b ............t.;[ 43 4f 50 51 41 41 36 4a 41 42 33 37 2d 30 39 36 COPQAA6JAB37-096 31 2d 30 33 56 30 33 20 01 00 46 00 00 00 00 cf 1-03V03 ..F..... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 53 46 50 2d 48 31 30 47 42 2d 43 55 33 4d 20 20 SFP-H10GB-CU3M 20 20 20 20 30 38 00 00 00 00 00 00 00 00 00 b5 08.......... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Port 1/0/7 vendor_name = CISCO-TYCO vendor_sn = TED1546BA1S date_code = 1511090 vendor_pn = 1-2053783-2 vendor_rev = P eeprom data = 03 04 21 00 00 00 00 00 04 00 00 00 67 00 00 00 ..!.........g... 00 00 03 00 43 49 53 43 4f 2d 54 59 43 4f 20 20 ....CISCO-TYCO 20 20 20 20 00 00 40 20 31 2d 32 30 35 33 37 38 ..@ 1-205378 33 2d 32 20 20 20 20 20 50 20 20 20 01 00 00 0d 3-2 P .... 00 00 00 00 54 45 44 31 35 34 36 42 41 31 53 20 ....TED1546BA1S 20 20 20 20 31 35 31 31 30 39 30 30 00 00 00 e5 15110900.... 81 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 74 04 3b 5b ............t.;[ 43 4f 50 51 41 41 36 4a 41 42 33 37 2d 30 39 36 COPQAA6JAB37-096 31 2d 30 33 56 30 33 20 01 00 46 00 00 00 00 cf 1-03V03 ..F..... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 53 46 50 2d 48 31 30 47 42 2d 43 55 33 4d 20 20 SFP-H10GB-CU3M 20 20 20 20 30 38 00 00 00 00 00 00 00 00 00 b5 08.......... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Port 1/0/8 vendor_name = CISCO-TYCO vendor_sn = TED1552BVQC date_code = 1512210 vendor_pn = 1-2053783-2 vendor_rev = P eeprom data = 03 04 21 00 00 00 00 00 04 00 00 00 67 00 00 00 ..!.........g... 00 00 03 00 43 49 53 43 4f 2d 54 59 43 4f 20 20 ....CISCO-TYCO 20 20 20 20 00 00 40 20 31 2d 32 30 35 33 37 38 ..@ 1-205378 33 2d 32 20 20 20 20 20 50 20 20 20 01 00 00 0d 3-2 P .... 00 00 00 00 54 45 44 31 35 35 32 42 56 51 43 20 ....TED1552BVQC 20 20 20 20 31 35 31 32 32 31 30 30 00 00 00 02 15122100.... 81 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 74 04 3b 5b ............t.;[ 43 4f 50 51 41 41 36 4a 41 42 33 37 2d 30 39 36 COPQAA6JAB37-096 31 2d 30 33 56 30 33 20 01 00 46 00 00 00 00 cf 1-03V03 ..F..... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 53 46 50 2d 48 31 30 47 42 2d 43 55 33 4d 20 20 SFP-H10GB-CU3M 20 20 20 20 30 38 00 00 00 00 00 00 00 00 00 b5 08.......... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ (M4300-8X8F) #
