BaldwinA
Oct 25, 2021Aspirant
M4300-96X Max POE 15W ports
I have just seen this small snippet in the spec sheet for the M4300-96X switch. *Only first 6 slots are delivering PoE power to APM408P cards for 48 PoE+ ports per switch. Since POE is a cop...
schumaku
Oct 25, 2021Guru - Experienced User
Yes, this is related to the power lane availability to the first six slots, and also mentioned on the module specs:
- Port card with 8-port 100M/1G/2.5G/5G/10GBASE-T PoE+
- Fits into one front slot of M4300-96X Modular Managed Switch
- M4300-96X offer 12 slots in 2RU for 8x10G or 2x40G port cards
- PoE is supported up to 48 x 10G PoE+ 30W per system (first 6 slots)
- 1440 W PoE Budget with 2 x APS1200W shared PSUs
- ProSAFE LIFETIME Limited Warranty/NBD Replacement/Online Support
