BaldwinA
Oct 25, 2021Aspirant
M4300-96X Max POE 15W ports
I have just seen this small snippet in the spec sheet for the M4300-96X switch. *Only first 6 slots are delivering PoE power to APM408P cards for 48 PoE+ ports per switch. Since POE is a cop...
schumaku
Oct 25, 2021Guru - Experienced User
Sigh, yes, two M4300-96X enclosures, but both can be configured into a single stack of course. LaurentMa can you confirm this svp.?
LaurentMa
Oct 26, 2021NETGEAR Expert
Sure thing, the M4300-96X can be stacked as any other M4300 switch (max. 8 switches in one stack). Stacking is possible when converting the 10G ports and/or the 40G ports into Stack ports. Up to 16 ports per switch can be used as Stack ports, but only 10G ports and 40G ports.
Two M4300-96X switches can be paired in a stack, yes. Important consideration is the stacking interconnect (how much bandwidth will need to traverse the stack). To get 80 ports delivering PoE+, a stack of two M4300-96X is elegant solution.
Feel free to use the M4300-96X configurator to design each M4300-96X switch:
https://www.netgear.com/96x-config
Let me know of any questions,
