Insightava
Apr 08, 2024Aspirant
m4300-96x POE++
Using a m4300-96x switch with poe+...unfortunately its like 1 watt shy of keeping the wax630e APs at full power. Any insight into a poe++ module coming or workaround???
schumaku
Apr 08, 2024Guru - Experienced User
It's a little bit more, or a lot more than just one Watt from the PoE+ available 25.5W at the PD to feed a fully active WAX630 with 30.1 W, a WAX630E with 27.64 W, the WBE750/WBE758 with 39 W.
Have not operated a WAX630 on a pure 802.3at PSE recently - what will the radios (4x4 2.4 GHz, 4x4 5 GHz low, 4x4 5 GHz high) resp. the WAX630E on a pure 802.3at PSE recently - what will the radios (2x2 2.4 GHz, 4x4 5 GHz, 2x2 6 GHz) be rated down then?
