mmancini's avatar
mmancini
Follower
Mar 02, 2022
M4300-96x with 40Gb apm402xl module Not linking with Intel XL710-Q2
Hello,  I have an M4300-96X with a APM402Xl 40GB module in it.  I am connecting it to an intel XL710-Q2 network card using the AXLC763 direct attach cable.  I am unable to get a link between these 2 devices.  I have tried 2 different network cards in 2 different servers.  I have swapped the module to a different port as well as tried a 2nd apm module.  The switch links if I connect the switch to itself and the card links if I connect the card to itself.  But I am not able to get the card and the switch to link.  I am running Server 2019 standard on the server right now.  I have installed the latest drivers from Intel.  Any help would be appreciated.
Thanks,
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    mmancini,
    Welcome to the community! :cathappy:
    About this, it means that the APM402XL works fine since it links when you connect the switch to itself.  The same as with the Intel XL710-Q2 which also works fine because it links if its connected to the card itself.  It is a possible compatibility issue between the APM402XL and the Intel XL710-Q2.
    I suggest you to open a support ticket with the NETGEAR Support here at anytime for further investigation.  Kindly state your concern as well as you may include a link to this post.
    DaneA
    NETGEAR Community Team
ProSupport for Business
