spopuri's avatar
spopuri
M4300 ACL's
Hello,   I would like to create an ACL on the web interface to allow traffic from client to licensing server on a particular port.   Please see the attached screenshot and let me know if it is ri...
  • Retired_Member's avatar
    Retired_Member
    May 20, 2020
    Hi spopuri
    Welcome to Community!
    Do you want to only allow DIP=10.3.200.40 and UDP D-Port from 27000~27009 packet fowarding on the binding port? But this is only for Client->Server direction, so what about Server->Client direction? Allow or dely? Currently your config ACL will deny all packet that from Server->Client direction, is it your expected behavior?
    If you want to allow both two direction traffic, you can add one more rule that permit with SIP=10.3.200.40 and UDP S-Port from 27000~27009(need you confirm if it's match your traffic that from Server->Client), then bind this ACL to the port.
    Eric
ProSupport for Business
