spopuri
May 13, 2020Aspirant
M4300 ACL's
Hello, I would like to create an ACL on the web interface to allow traffic from client to licensing server on a particular port. Please see the attached screenshot and let me know if it is ri...
- Retired_MemberMay 20, 2020
Hi spopuri
Welcome to Community!
Do you want to only allow DIP=10.3.200.40 and UDP D-Port from 27000~27009 packet fowarding on the binding port? But this is only for Client->Server direction, so what about Server->Client direction? Allow or dely? Currently your config ACL will deny all packet that from Server->Client direction, is it your expected behavior?
If you want to allow both two direction traffic, you can add one more rule that permit with SIP=10.3.200.40 and UDP S-Port from 27000~27009(need you confirm if it's match your traffic that from Server->Client), then bind this ACL to the port.
Eric
spopuri
May 22, 2020Aspirant
Thank you very much Retired_Member
spopuri
May 25, 2020Aspirant
Hello Retired_Member
I have another question, If I write ACL rules to allow only port specific traffic. Will it block all other traffic by default?
Thanks,
Sravan
- Retired_MemberMay 25, 2020
Yes, sure. There is one default rule that will deny all traffic at the last.
So it mean, if you want to add one rule to deny the specific traffic, you must add last rule with permit all.
