andrewl_
Oct 16, 2020Aspirant
M4300 and Vlans not working
Hi all,
We just bought a M4300 switch and i are having som issues with VLANS , for some reason i cant get it to work.
Step one. I disabled the routing.
Step two.
I followed this guide . > https://kb.netgear.com/31026/How-to-configure-a-VLAN-on-a-NETGEAR-managed-switch
Tagged port 22-24 with VLAN 220, disabled all other VLAN´s on thoose ports.
2 ports from the firewall in HA mode. So only one of them two ports will be active at the same time .
1 ports to our main switch ( HP/ARUBA ) for 1 vlan. Its pretty basic. but for some unknown reason it dont route traffic.
If i go straight from Firewall to Aruba Switch everything works like it should. So i assume i am missing something basic.
I did not do the PVID , since thoose 3ports are in use for Firewalls and other switch.
Any help would really be appreciated .( i come from a HP/Aruba world )
Andrew
After 3 vlans reset and then 1 hard reset , same config worked...
Andrew
1 Reply
- andrewl_Aspirant
Andrew
