dialsc
Mar 24, 2020Guide
M4300 Boot Freeze after FW upgrade
Hi I just went through the firmware upgrade on a M4300-28G switch from version 12.0.9.3 to 12.0.11.8. After the reboot the switch was not comming up again. Re-powering the switch and watching on ...
- Apr 13, 2020
Hello
I'm happy to announce that support just shared a new firmware version (12.0.11.10) with me which, after installation, works.
Thank you NETGEAR!
Best
dialsc
dialsc
Mar 25, 2020Guide
Hi DanielZhang
I did what you asked me to do and send all the data/files collected to the support mail address.
I hope it helps and if you need anything else please just ask/call/what ever... ;)
Kind regards
dialsc
DanielZhang
Mar 26, 2020NETGEAR Expert
NETGEAR team are under analysis about this abnormal behavior.
We will update here when get any update .
Thanks.
- dialscMar 26, 2020Guide
Hi all
I can confirm that NETGEAR support has started working on this case. I'll also keep you posted once I/they know more.
Best
dialsc
- dialscApr 13, 2020Guide
Hello
Thank you NETGEAR!
Best
dialsc
- msiApr 14, 2020Luminary
Thanks for keeping us posted, that's definitely good news! I'm looking forward to a regular release available in the downloads.
To add some context for other readers: It's quite likely that dialsc got a beta or special build to test like I did in another instance. It usually takes some additional time between such a feature build (or whatever you want to call it) and a build posted to the downloads section.
Likely other included bugfixes need to be validated first, then it has to go through Netgear's internal QA. (At least that how it has been in previous cases of mine.)
- Jan 17, 2024Retired_Member
