TimJL
Oct 22, 2020Tutor
M4300 Firmware Upgrade Path
Hi all,
Can I upgrade an M4300-52G-PoE+ from version 12.0.2.20 straight to 12.0.11.15 or 12.0.11.16?
I have reviewed all the release notes from 12.0.4.8 through to 12.0.11.16 and there are no noted firmware jumping limitations or requirements (eg: You must upgrade to version x before going to version y) but I wanted to check here to ensure its ok to jump from 12.0.2.20 straight to 12.0.11.16
Thanks.
T
- Retired_MemberOct 27, 2020
Hi TimJL
Welcome to Community!
It's ok to upgrade image from v12.0.2.20 to v12.0.11.16, but after upgrade fiwmware, please clear cache and refresh the page, due to there is some GUI menu changes. If you don't refresh the page, maybe some of the new GUI menu cannot display correctly.
Hope it helps!
Eric
1 Reply
- Retired_Member
Hi TimJL
Hope it helps!
Eric
