Purduephotog
Dec 17, 2018Guide
M4300 CARP packet support
Have a M4300 24x24; just tried upgrading to Firmware .10, but it appears both .9 and .10 have bugs where the 'ports' menu isn't functioning (404 missing).
That said, I am utilizing 2 copper 10g...
Purduephotog
Dec 19, 2018Guide
That is a very painful answer to learn. After searching and trying to contact pre-sales support, finding out now that CARP isn't supported (as it is really just multicast and needs to be re-broadcast) when VRRP is supported ... ouch.
That said, here is a screenshot I forgot I saved. The firmware loaded is either .9 or .10. When you attempt to navigate via the switching, then ports, menus the page returns 404. I did not roll back any further. Right clicking and manually entering th port menu may have been working but I was trying to diagnose other issues.
-You can also see the .13 HA interface failing to respond to a ping, whereas the others were still working.
LaurentMa
Dec 20, 2018NETGEAR Expert
Thank you, the team is willing to diagnose it with more details. Our Tech Support team sent you a PM yesterday asking for the tech-support file, too. Please send the tech-support file either way (to me, or to the Tech Support team). With it, we will be able to exactly find out what's wrong.
In looking at your management IP address (192.168.0.0 scheme), I am assuming you are using the OOB service port. If you are managing the switch from the in-band, then you possibly have a conflict with the OOB service port IP scheme. The OOB service port IP scheme should be changed from 192.168.0.0 to something else, like 192.168.100.0 before you can use 192.168.0.0 scheme on the Management VLAN through the in-band.
Thank you,
