shultzee13
Nov 01, 2024Aspirant
M4300 GSM4352 question
Is there a way to turn off individual ports on this switch? We have a problem with multicasting and need to be able to turn off individual ports. Thank you Eric
schumaku
Nov 02, 2024Guru - Experienced User
Dear Eric,
Of course, you could disable slelected port(s) on a Manged switch, or on a Smart Managed switch as you asked in your other post:
But I feel there is a much bigger issue than the simple question you have asked here.
-Kurt.
