EDV01
Oct 14, 2024Aspirant
M4300 how to delete VLAN from inluce list
Hello, how can i delete a vlan from the include list in general mode with cli? There ist no "no"-form or "add" od "remove" command like : "switchport trunk allowed vlan remove 234" I try t...
BrianL
Oct 17, 2024NETGEAR Moderator
Hi EDV01,
Can you try #vlan participation exclure234
or
Navigate to the VLAN settings: Use the command vlan database to enter VLAN configuration mode.
Delete the VLAN: Use the command no vlan <VLAN_ID> to delete the VLAN from the include list.
NOITE: Replace <VLAN_ID> with the ID of the VLAN you want to delete.
Kind regards,
BrianL
EDV01
Oct 18, 2024Aspirant
Hello,
ok, i can use "vlan participation exclude <vlan-id>"
This removes the VLAN from the include-list and put it to the exclude-list.
Over time this fills then the exclude-list....
(I dont want to delete the VLAN, only change the config of this trunk interface.)
interface 1/0/30
ip dhcp snooping log-invalid
vlan pvid 1010
vlan ingressfilter
vlan participation exclude 1
vlan participation include 1010,1020
exit
(Access-A07)(Config)#interface 1/0/30
(Access-A07)(Interface 1/0/30)#vlan participation exclude 1020
(Access-A07)(Interface 1/0/30)#exit
(Access-A07)(Config)#do show running-config interface 1/0/30
interface 1/0/30
vlan pvid 1010
vlan ingressfilter
vlan participation exclude 1,1020
exit
It seems to me that using cisco-like commands like "switchport mode trunk" and "switchport trunk allowed vlan x,y,z" are prefered now over general mode.
If configure an interface as a trunk in general mode with
"vlan participation 10,20,30,40"
"vlan pvid 10"
"vlan tagging 20,30,40"
it is not shown as a trunk in the Web-GUI.
When trunk is selected in the Web-GUI "switchport mode"- and "switchport trunk allowed vlan"-commands are inserted in the config.
Are these commands preferd now?
regards
Jörg
M4350-48G4XF with FW 14.0.2.26 (and older... 14.0.18...)
