ARPcPro
Dec 12, 2019Aspirant
M4300 InterVLAN between several switches
Hello, I've been trying to setup a few M4300-24X24F to make my scenario work, but these seem to work a bit different from the ciscos I’ve used in the past. My setup right now is 4 separate off...
kevin_hong
Dec 18, 2019Apprentice
Hi ARPcPro,
Welcome to community,
I can not access https://imgur.com/yufHx7A , i think core switch was M4300-24X24F in your network, Right?
If you want all pc to access each other, your just neet to set all routing vlan gateway ip address in M4300-24X24F,
Please let me know if you have more detailed requirements.
BTW: Could you please privode your network topo? it will be more helpful.
Thank you
ARPcPro
Jan 05, 2020Aspirant
Thank you for the answer. All the 4 PCs (4 offices) have an IP address 192.168.202.10. At the moment all the offices have each own switch with VLAN 202.
Even if I set a different VLAN for each office, I think I would still have the same IP conflicts somehow when I interconnect the switches.
The link https://imgur.com/yufHx7A seems fine. Are sure it is not being blocked by some adblocker?
- kevin_hongJan 06, 2020Apprentice
Hi ARPcPro ,
You can not configure the confilicting ip address in vlan 202.
You can set different vlan for each office, it means different vlans have different subnet address and all subnet gateway address was set in the M4300.
If you want to avoid manual configuration problems, you can configure DHCP server for each office vlans in the M4300 switch.
Thank you
