BenBierbaum
Oct 19, 2018Follower
M4300 iSCSI awareness
We are using the M4300-12x12F switch at 2 client locations for iSCSI traffic between our storage array and VMWare hosts. This switch has been working great and we have really had zero storage issues...
DaneA
Oct 25, 2018NETGEAR Employee Retired
Hi BenBierbaum,
Welcome to the community! :)
I inquired your concern as well as your questions to the higher tier of NETGEAR Support. As per the higher tier of NETGEAR Support, "VPT is Layer 2 QoS (802.1p) where DSCP is layer 3. Both work in a similar way: the priority chosen (along with the queue mapping settings) determines the egress queue used for iSCSI packets on the switch. Since VPT is in the layer 2 header, the priority is lost if the packet is routed. With DSCP the priority set on the packet can be kept even if it is routed (depending on how the routers routing the packets are configured)."
DaneA
NETGEAR Community Team
- DaneANov 07, 2018NETGEAR Employee Retired
I just want to follow-up on this. Let us know if you have further inquiries.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
