Ghouse54
Sep 10, 2018Aspirant
m4300 natting feature
Do we have Natting feature in Netgear manageable switch ???
- Sep 10, 2018
Hi Ghouse54
Thank you for your message. No, we don't have NAT firewalling in our Fully Managed Switches. If that's what you require, I am afraid I won't have an alternative for NAT.
LaurentMa
Sep 10, 2018NETGEAR Expert
Hi Ghouse54
- Ghouse54Sep 13, 2018Aspirant
Thank you for the answer
I would like to clarify if we can connect SFP link from 10G sfp of M4300 to a 1G sfp of another switch. will it give uplink with this connection??
- LaurentMaSep 13, 2018NETGEAR Expert
Greetings,
Yes, sure! M4300 SFP+ ports are 1G/10G, just plug a 1G SFP transceiver in M4300 SFP+ port that is the same type as in your other 1G switch, and the link will come up (for instance, NETGEAR AGM731F for 1000BASE-SX on MMF).
