Greg_11's avatar
Greg_11
M4300 spine and leaf with more than 8 switches
I'm upgrading our networking infrastructure using M4300 switches which I was planning on installing in a spine and leaf topology. In location A we have a pair of 12X12F's that we're going to use as t...
  • DanielZhang's avatar
    DanielZhang
    Nov 09, 2016
    Hi Greg,
    For your 1st question, " what will I do if I need to add another 52G-PoE+ leaf? "
    I have add six M4300-52G-PoE+ as leaf In example "Location A" just as above reply.
    So your new M4300-52G-PoE+ will work together with leaf-spine stack same with other five M4300-52G-PoE+.
    2nd    " 12X12F switches in a leaf-spine stack with the two 52G (non-PoE) switches,The PoE switches would then be made into a normal stack,"
    I just suggest you to put M4300-52G-PoE+ into leaf-spine stack, because the five(six) M4300-52G-PoE+ need leaf-spine topology more than two M4300-52G in your network topology design.
    The five(six) M4300-52G-PoE+ is access layer and M4300-12X12F is core, it's a typical topology in leaf-spain network.
    But you can also add two M4300-52G into leaf-spine stack instead of five(six)M4300-52G-PoE+ just as you with.:smileyhappy:
    3rd  " When connecting the stacks together, how would the LAG memberships be best configured between the stacks? Static or Dynamic? STP? Enhanced Hashing mode?"
    The dynamic mode(LACP) will offer a better reliability link than static mode.
    I suggest you to configure LAG type to dynamic mode(LACP).
    You need to chose a hashing mode on LAG accord with your real network traffic due to every hashing mode has different purpose.
    such as:
    Src MAC,VLAN,EType,incoming port
    this mode just used for the packets came form different port with different source mac-address or 802.1q VLAN tag or Ethernet Type.
    Src IP and Src TCP/UDP Port Fields
    this mode just used for the packets with different source IP address and source TCP/UDP port
    Please check more information about other hashing mode as below:
    4th "Should I be using dynamic routing protocols between the three stacks? Any other suggestions?"
    This is not necessarily to chose dynamic routing protocol between three stacks.
    For location A,
    The static route will work fine with simple L3 network just like yours due to many switches worked into same stack.
    Or you can use OSPF to connect stack A and stack B because its worked in a same LAN due to more reliability and expandability.
    For location B,
    You said it connected to location A with WAN, I'm not sure your ISP allow dynamic routing protocol or not.
    So please use the special protocol (OSPF/RIP/static route) accord with the regulation from ISP.
    May the solution help you.:smileyhappy:
    Daniel.
ProSupport for Business
