knarfer
Jan 03, 2018Aspirant
m4300 stack-port errors
Hi, we have a stack with 4 m4300-24x24F switches. in the log files there are many (every minute) errors related to the stack ports ("errors detected on stack-port" and "Multiple consecutive errors ...
Hopchen
Jan 03, 2018Prodigy
Hi knarfer
This is likely a problem with either the stacking cable or modules (if you use SFP ports for the stacking).
What stacking connection are you using?
Thanks
- knarferJan 04, 2018Aspirant
Hi,
we use brand new stacking cables and sfp modules
regards
Frank
- HopchenJan 04, 2018Prodigy
Hi again,
In almost all instances, stack-port errors is a cause of either bad cables or bad modules. I suggest you reach out to support and let them have a look. If these are Netgear modules, they can look into an RMA if needed.
You can log a case via: https://my.netgear.com/registration/login.aspx
Cheers
