knarfer
Jan 03, 2018Aspirant
m4300 stack-port errors
Hi, we have a stack with 4 m4300-24x24F switches. in the log files there are many (every minute) errors related to the stack ports ("errors detected on stack-port" and "Multiple consecutive errors ...
knarfer
Jan 04, 2018Aspirant
Hi,
we use brand new stacking cables and sfp modules
regards
Frank
Hopchen
Jan 04, 2018Prodigy
Hi again,
In almost all instances, stack-port errors is a cause of either bad cables or bad modules. I suggest you reach out to support and let them have a look. If these are Netgear modules, they can look into an RMA if needed.
You can log a case via: https://my.netgear.com/registration/login.aspx
Cheers
