marcinko
Jan 15, 2020Aspirant
M4300 stacked - The system is restarting due to inconsistent state 24 in file: osapi_task.c line 213
Hello, I have a problem with the stack. The following information appears in the logs, after which one of the switches stops working. Restarting the switch improves the situation but only for a limi...
kevin_hong
Jan 16, 2020Apprentice
Hi marcinko
Welcome to community,
Could you please provide the "tech support" to me ?
I will be try to re-created the issue and find the root cause of the issue ASAP.
How-do-I-send-diagnostic-files-from-my-Managed-Switch-to-NETGEAR-community-moderators
Thank you
- marcinkoJan 17, 2020Aspirant
Hi, thanks for the quick reply.
I sent the support file to the support email address. According to the information provided on the site.There is currently no problem, I have withdrawn the firmware to version 12.0.8.15
