kuflowe_mocne's avatar
Jun 03, 2025
M4350-12X12F SNMP v3 traps configuration
How to configure SNMP v3 Traps on this switch?
I have current snmp config:
snmp-server sysname "CENSORED-SYSNAME"
snmp-server user "zabbix-netgear" DefaultWrite auth-sha512-key CENSORED-AUTHKEY priv-aes128-key CENSORED-ENCKEY
snmp-server password-strength
snmp-server v3-host CENSORED-IP "zabbix-netgear" traps priv
acl-trapflags
snmp-server enable traps captive-portal
snmp-server enable traps mac-notification change
ip dvmrp trapflags
ip pim-trapflags
However snmptrapd says that this user has authentication failure, here is part of the config
createUser -e SWITCH_ENGINE_ID zabbix-netgear SHA "CENSORED-AUTHKEY" AES "CENSORED-ENCKEY"
Despite having correct engine ID, correct keys switch cannot properly authenticate? I think problem lays in switch itself because sending test trap using snmptrap with same engine ID, auth key and encryption key works fine.
Firmware 14.0.4.14
1 Reply
  • schumaku's avatar
    schumaku
    This could be a simple bug or an oversight by the product engineering. While learning about a possible soluition would be great for the community, there will be more success by contacting Netgear Support, or please reach out to the mailto:[email protected] team, under the lead of LaurentMa​ - please keep us posted about the results.
    -Kurt.
ProSupport for Business
