gn00347026
Apr 03, 2023Guide
M4500 (csm4532) , the BMD LED shows amber
Hi Everyone I've two M4500-32C, one of it, the BMC LED show amber and blinking, any one know the reason? I use "show bmc" via the cli, both settings are the same. thank you.
- Apr 12, 2023
... anyone ?
gn00347026
Apr 06, 2023Guide
Anyone know the answer or how to resolve the above issue? thank you.
- gn00347026Apr 12, 2023Guide
... anyone ?
- sinanjpFeb 09, 2026Initiate
For anybody looking for the answer to this in the future (as I guess OP already figured this out):
You need to plug in both PSU.
I had the same problem and found literally nothing on this, except for this thread. The manual also doesn't mention this.I called support and they told me to plug in both PSU, which solved the issue.
