gn00347026
Apr 03, 2023Guide
M4500 (csm4532) , the BMD LED shows amber
Hi Everyone I've two M4500-32C, one of it, the BMC LED show amber and blinking, any one know the reason? I use "show bmc" via the cli, both settings are the same. thank you.
- Apr 12, 2023
... anyone ?
gn00347026
Apr 12, 2023Guide
... anyone ?
sinanjp
Feb 09, 2026Initiate
For anybody looking for the answer to this in the future (as I guess OP already figured this out):
You need to plug in both PSU.
I had the same problem and found literally nothing on this, except for this thread. The manual also doesn't mention this.
I called support and they told me to plug in both PSU, which solved the issue.
