JKas's avatar
JKas
M4500 download tech-support file via tftp
How can I download (export) the tech-support file via tftp?
I'm able to download the running-config with below command:
copy running-config tftp://172.140.0.25/esw1-running-config
Thanks.
  • schumaku's avatar
    schumaku
    The so called tech-support file is a collection of several documents and can be generated downloaded in the Web UI only
    -> How do I send diagnostic files from my Managed Switch to NETGEAR community moderators?
    Scroll down to -> "To get the tech support file."
    1. Log in to the command line interface of the switch and from enable mode run the command show tech-support.
    2. On the admin page of the switch, go to Maintenance - Upload / Export - HTTP File Upload / HTTP File Export.
    3. In the File Type drop-down menu, choose Tech Support and click A
    • JKas's avatar
      JKas
      Thanks schumaku.
      the M4500 didn't have web interface, only CLI.
      I can read the tech-support file on command line. is any way I can create a txt or plain file in the M4500 to export it? or individual files as the running-config?
      • schumaku's avatar
        schumaku
        How true, always forget about this 8-) LaurentMa can you assist your customer please?
ProSupport for Business
