HOSchool
Mar 03, 2021Follower
M5300 & ProSafe Gigabit Quad
I currently have a Netgear ProSafe off the back of my router which then links to my M5300 switch. I'm losing 360Mb out of 500Mb of speed at the setup is double NAT.
I want to remove my ProSafe and use the Firewall on the Router but I need sort out my routing. My M5300 has learned routes for my VLANS from the ProSafe but I need to add the routes to the M5300. It currently wont let me as the routes are pointing to itself if I do.
ProSafe - 192.168.10.254
M5300 - 192.168.10.250
VLANS - 192.168.11.0, 12.0, 13.0,14.0 15.0, 16.0
Routing on ProSafe point all VLANS to 192.168.10.250
I removed the ProSafe and did test without the routing added to the M5300 and just the .10 network could access the internet. Can anyone help with what routing I need to put in for the VLANS to access the internet.
1 Reply
- DaneANETGEAR Employee Retired
What is the specific model of the NETGEAR ProSAFE device you are referring to that is linked to the M5300 switch?
Is your router a NETGEAR device as well? If yes, what is the model of it?
What are the corresponding current firmware version of your NETGEAR devices?
It would be best that you post a detailed diagram of your existing network setup and also a detailed diagram of the network setup that you want to implement so that other community members may share their ideas to help you.
DaneA
NETGEAR Community Team
