LerchUK610's avatar
LerchUK610
Follower
May 27, 2018
M5300-28G v1h1 (11.0.31) Missing DHCP L2 Relay
Can anyone tell me whats happened to the DHCP L2 Relay feature please? It was there in version 10 and well documented, but disappered in 11.
I've configured the UDP Relay for both of my Windows 2012R2 servers, but I would like the ganular control of which VLANs will be relayed.
Any ideas?
Thank you
1 Reply
  • Retired_Member's avatar
    Retired_Member
    Hi LerchUK610,
    Welcome to the community!
    Yes, just as you said, some security related features(such as: DHCP L2 Relay, DHCP Snooping, DAI and so on) are limited by SDM template on v11.0.x firmware.
    It depends on what SDM template that you use.
    System > Management > SDM Template Preference
    - If you use a template for a multicast environment, then you won't have things like DHCP L2 Relay, DHCP Snooping, DAI, etc.
    - If you use a template for an environment not focused around multicast, then you will have other features like DHCP L2 Relay, DHCP Snooping, DAI and so on.
    Depends on what you need to use the switch for - set the SDM template accordingly. SDM templates enable you to reallocate system resources to support a different mix of features based on your network requirements.
    Pay attention: Change SDM Template will erase the configuration of the switches, so please save and export the configuration file, then restore the configuration after apply the new SDM Template.
    Hope it helps!
    EricZ
    NETGEAR employee
ProSupport for Business
