tomtcs
Feb 02, 2022Follower
M5300-52G-POE+ Does noot boot. No UBOOT - Amber solid Power - amber ports 49/50
M5300-52G-POE+ fails to boot after trying to perform a factory reset and erasure of the firmware to replace it with a new copy. Now during a reboot, there's no UIBOOT sequence, no access via serial ...
DaneA
Feb 03, 2022NETGEAR Employee Retired
Welcome to the community! :)
I suggest you to open a support ticket with NETGEAR Support here at anytime for a hardware check. If ever your M5300-52G-POE+ is proven faulty, an online replacement will be processed for as long as its still within the hardware warranty.
DaneA
NETGEAR Community Team
