BryantP
Jul 27, 2022Tutor
M5300 Static Routing
Happy Wednesday. Looking for a bit of guidance Looking to be able to split some traffic and send in different directions. Setting the static route on the switch works exactly how it is suppose ...
- Jul 29, 2022
So for anyone that stumbles upon this later with the same ish type of setup. I did get it working
I got rid of my VLAN 777 routing. Instead I assigned that address to Port 1 on the switch within IP Routing IP Interface Config. Worked exactly how I needed to after that.
BryantP
Jul 27, 2022Tutor
And routing Mode is Enabled.
BryantP
Jul 29, 2022Tutor
