Electrical
Jun 08, 2019Tutor
M6100 Link Down Events
We have a switch with 40 'link down' events listed in the log for physical ports 1/0/43 & 2/0/43 but none listed for the lag that they're associated with. There are a mere 38 broadcasts listed for th...
DaneA
Jun 10, 2019NETGEAR Employee Retired
Hi Electrical,
What devices are connected to ports 1/0/43 & 2/0/43? It would be best if you post an image of your detailed network setup.
What is the current firmware version of your M6100 switch?
In order to analyze the logs from the M6100 switch, I suggest you to open a chat or online support ticket with NETGEAR Support at anytime.
DaneA
NETGEAR Community Team
Electrical
Jun 10, 2019Tutor
The firmware is 11.0.0.31 for both blades in the M6100 and they're configured in a LAG on ports 1/0/43 & 2/0/43 to an EdgeRouter ER-8-XG running 2.0.3. Both devices are using LACP and aren't experiencing any problems aside from the aforementioned. I'm not sure it's even a problem...more of a curiosity at this time.
