egonbar
Feb 13, 2020Aspirant
Mac based autenthication access port to switch
Hello!
I want to control the access of the pcs of my office. Via mac.
So, i want to make a data base with the autorized macs.
So, when the pc with autorized ip connect to a port of our switches... the switch.. i suppose send the mac to a external radius... that answrer the switch is autorized ip..so swich config vlan1 to the port of the pc.
When a pc with no autorited, the server radius answer not autorhized, the switch assign a vlan 10 to the port wher is connected the pc.
1.how must i configure it in the switches?
security port autehthication: mac based or auto??
security: 80211x administrative mode enable? vlan asignment dynamic enable?
radius server configuration: ip, name port 1812, secret, secret configured yes, primary server, messaga autnticacion yes?
radius configuration: aacount modeoff, radius 4 mode disable?
routing mode disable
2. I think my server radius is not receiving request... how can i very verify it? which command can i use to verify that switch is right conneted to radius server?
3. how must i configure radius server?
please, give a complete guide.. i am lost configuring it.
which is the vendor id for netgear to use in radius?
who does it works? the radius send the switch a message of mac autorized or not?
how can i create the bbdd mac? where? excel import?
thank a lot
1 Reply
- DaneANETGEAR Employee Retired
Let me share the following articles below and use it as your guide:
How do I assign VLANs using RADIUS on my managed switch using the web interface?
How do I assign VLANs using RADIUS on my managed switch using CLI commands?
Dynamic VLAN assignment using RADIUS
DaneA
NETGEAR Community Team
