Sanju_13
Nov 28, 2024Follower
Management ACL disable
Hi,
I have a management ACL configured on my switch, but my SNMP walk is failing due to an incorrect ACL configuration. I want to modify the configuration, but the switch indicates that I need to disable the Management ACL first.
If I disable the ACL from the management interface, will my SSH connection to the switch be terminated ?
Thanks in advance.
No RepliesBe the first to reply
