longbow47
Feb 28, 2019Aspirant
Management VLAN / webinterface reachable via multiple IPs
Hello @ all,
i created a management vlan 99 on stacked M4300 and changed the configuration (see picture above).
It worked and the webinterface is reacha...
MrJoshW
Mar 05, 2019NETGEAR Employee Retired
Hello,
Before changing the management vlan to 99, what IP address was 192.168.0.243 associated with? Was it vlan1? Are any of your other vlans able to access the web management interface?
longbow47
Mar 07, 2019Aspirant
Yes 192.168.0.243 was the management webinterface from vlan1
i changes it to vlan99 and i changed the ip.
but the webinterface is still accessable from both IPs.
Could it have something to do with the routing mode?
There i can still see the old ip (learned routes).
- May 25, 2022Retired_Member
