Dirkas
Apr 10, 2019Follower
MIB files for GS728TPPV2
Good Morning. I am looking for the MIB files for the following switches. GS728TPPV2 , M5300 - 28GF3, GS418TPP
To be used with BMS.
Thank you very much.
JohnC_V
Apr 12, 2019NETGEAR Employee Retired
Hi Dirkas,
Welcome to our community! :)
Most of our MIB files can be found on their respective support website. Here is the MIBs for 5300-28GF3, and GS418TPP. I'll send a request for the GS728TPPv2 and will just edit this post to provide you the link. I'll send you a pm once I got it.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnCarloV
NETGEAR Community Team
JohnC_V
Apr 15, 2019NETGEAR Employee Retired
As per checking, GS728TPPv2 has the same MIB with the GS752TP.
JohnCarloV
