hugostiglitz's avatar
hugostiglitz
Initiate
Feb 12, 2019
GS108Tv2 SNMP MIB files
Hi,
I am after the MIB files for the GS108Tv2
some of the documentation make reference to "-SWITCHING-MIB" and "IF-MIB" but be buggered if I can find these to download anywhere.
Thanks,
  • Hi hugostiglitz,
    Welcome to the community! :)
    You can downlaod the GS108Tv2 MIB files on this link.  The link will expire after 2-3 days.
    If ever you do not have further concerns, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi hugostiglitz,
    DaneA
    • hugostiglitz's avatar
      hugostiglitz
      Initiate
      Thanks for that,
      is there any reason why these are not available from the downloads (firmware) page?
      • DaneA's avatar
        DaneA
        hugostiglitz,
        You're welcome! :)
        I have already inquired if its possible to include the MIB files in the download page.  I'll follow-up on it.
        DaneA
ProSupport for Business
