Bingo32's avatar
Bingo32
Follower
Mar 07, 2019
MIB-files for GS108Tv2
Could someone please post a link to download the MIB files for a GS108Tv2.  I'm setting up PRTG  and seeing how much more info I can get by setting up the mib files.
Thank you.
1 Reply
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi Bingo32,
    Here is the MIB for GS108Tv2. No password needed and the link will expire after 48 hour period.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
