Peter_Che
Sep 26, 2025Guide
GS108TV2 hard reset
Hi! Is there a way to hard reset a Netgear GS108TV2?
Thanks
there should be a hard reset button on the front of it. The guide goes over it.
https://www.downloads.netgear.com/files/GDC/GS108Tv2/GS108Tv2_HIG_EN.pdf
This button doesn't help and doesn't respond.
What happens when you push and hold the button while powered on?
Do the lights blink? Anything change?
There is no button Factory Defaults
I apologize, I found a button Factory Defaults !!
Glad you found it. I take it that it worked?
Yes, thank you
