Peter_Che
Sep 26, 2025Guide
GS108TV2 hard reset
Hi! Is there a way to hard reset a Netgear GS108TV2? Thanks
- Sep 26, 2025
there should be a hard reset button on the front of it. The guide goes over it.
https://www.downloads.netgear.com/files/GDC/GS108Tv2/GS108Tv2_HIG_EN.pdf
Sep 26, 2025Guru - Experienced User
Glad you found it. I take it that it worked?
